  2. Functional Verification
  3. Solved :: added tcl script in the menu instead::Add tcl...
  • Subscribers 68
  • Views 5009
Solved :: added tcl script in the menu instead::Add tcl script to tcl/tk Application Dashboard
vidyutt
vidyutt over 13 years ago
 I have created a small tcl script to modify the some properties on the Title Block. I wish to add the Script to the TCL/Tk Applications Dashboard.I followed the instructions in the OrCAD_Capture_TclTk_Extensions.pdf. I have added the script in the folder “C:\Cadence\SPB_16.5\tools\capture\tclscripts\capUtils” and modified the file capApps.tcl in the “C:\Cadence\SPB_16.5\tools\capture\tclscripts\capForms” folder. I restart my Orcad Session, I can see the entry in the dashboard. However, upon clicking on ‘Launch’ I get the error "error ::capTitleBlockEditUtil::EditTitleBlockOnPage not defined"
my script is ::
package require Tcl 8.4
package require DboTclWriteBasic 16.3.0
package provide capTitleBlockEditUtil 1.0
namespace eval capTitleBlockEditUtil {
namespace export EditTileBlockOnPage
proc capTitleBlockEditUtil::EditTileBlockOnPage {} {
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
set lStatus [DboState]
set pDesignPath C:/ecad/staging/vila/bimu_1405135821/orcad/latest/0010/test.dsn
set lDesignPath [DboTclHelper_sMakeCString $pDesignPath]
set lDesign [$lSession GetDesignAndSchematics $lDesignPath $lStatus]
set pSchematicName SCHEMATIC1
set lSchematicName [DboTclHelper_sMakeCString $pSchematicName]
set lSchematic [$lDesign GetSchematic $lSchematicName $lStatus]
set pPageName PAGE1
set lPageName [DboTclHelper_sMakeCString $pPageName]
set lPage [$lSchematic GetPage $lPageName $lStatus]
set lTitleBlockId [$lPage GetTitleBlockDisplayed  $lStatus]
set Titile [$lPage GetTitleBlock $lTitleBlockId $lStatus]
set pPname Title
set lTitlePName [DboTclHelper_sMakeCString $pPname]
set lNameValue [DboTclHelper_sMakeCString]
$Titile  GetUserPropStringValue  $lTitlePName $lNameValue
puts [DboTclHelper_sGetConstCharPtr $lNameValue]
set pPropValue CHANGED
$Titile SetUserPropStringValue $lTitlePName $lPageName
  • oldmouldy
    oldmouldy over 13 years ago
    I am pretty sure that your "proc" is not in the namespace, I reckon you need a "proc ::capTitleBlockEditUtil::EditTitleBlockOnPage" to define the proc. Equally hacking in the supplied files is probably not too great an idea, for example, what happens if "Page" is not active? You might be better of extending the pop-up menu to add your utility since you can be sure what is active when the utility runs. This will also be easier to move around the releases. You can use the orcad_scripting email alias to access "real intelligence" on TCL scripting in Capture.
  • vidyutt
    Hi, i had written this script just for my demo purposes. For the actual script, i would be searching for all the active designs and their corresponding pages availablein the active session. Also where can i find more information on the "extending the pop-up menu to add your utility".
  • oldmouldy
    Try Chapter 10 of OrCAD_Capture_TclTk_Extensions.pdf, you must have looked in Chapter 11 for the Applications Dashboard stuff...
  • vidyutt
    Thanks for the info. Really appreciate it.
    I think i would try that out and choose to auto load this tcl script with each new session of Orcad. Thanks again
