  2. Functional Verification
  3. irun: Simulating an already generated snap-shot.
  • Subscribers 67
  • Views 18344
Abid
Abid over 13 years ago
 I want to generate a snap-shot with name house and simulate it later.
To generate snap-shot, I use the following command,
irun -elaborate -snapshot house source.sv
This results in a folder INCA_libs/house.lnx86.11.10.nc
To simulate the snap-shot house, I use the following command,
irun -r  worklib.house:sv
I get an error stating that the folder  INCA_libs/irun.lnx86.11.10.nc is missing.
I see that even though I use the -r option with irun, it does not use the snap-shot house.
I also tried the -R option, but even with that I get the same error.
I see that if snap-shot name is chosen as "irun", this error is not seen.
How do I make irun simulate the snap-shot house (snap-shot name other than "irun")?
Abid.
  • Shalom B
    Shalom B over 13 years ago
    I tried it using Incisive 12.20, not 11.10.
     irun -r house
     gave me
    irun: *N,NOSNPR: The default work directory (./INCA_libs/irun.lnx86.12.20.nc) is missing.  -r house was used and a matching -snapshot house scratch directory was found.  irun will imply the option -snapshot house.
    Loading snapshot worklib.house:sv .................... Done
    ncsim> source /p/icom/eda/cadence/incisive/12.20.002/tools/inca/files/ncsimrc
    ncsim> run
    ncsim: *W,RNQUIE: Simulation is complete.
    That is, I got a NOTE from irun, not an error. It still ran.
    If I run it like this:
    irun -r house -snapshot house
    I did not get even the note.
    Shalom
  • Abid
    Hi Shalom,
    Even with 11.10, irun -r house -snapshot house gives the correct output.
    Earlier, I used irun -r house which gave error. On adding, the -snapshot option, the error goes aways.
    But when we look at the output of irun -helpall, we see that -snapshot option is used to generate a snapshot. And in this case, we do not want to generate a snapshot, but want to simulate an already existing snapshot. So I am not sure if using -snapshot option in this case is correct.
    Abid.
  • Shalom B
    The answer is in the documentation.
    In the irun User Guide, it says,
    Note: If you run irun with the -snapshot option (or its alias -name) to specify a name for
    the simulation snapshot, you must include the original -snapshot option when you invoke
    irun with irun -r snapshot_name.
    -helpall just gives you a one-line description, not all the information.
    Shalom
  • Abid
    That answers my question.
    Thanks for your help Shalom.
    Abid.
