  2. Functional Verification
  3. IFV assertion check problem
  • Subscribers 67
  • Views 14779
stone14041
stone14041 over 13 years ago
When I  was running  a IFV assertion check,the result was "Pass",but the trigger item showed "Blank",and the Trace item showed "Not run".
 I want to know that whether the assertion check was OK or not.Was it a real pass?
  • JoergM
    JoergM over 13 years ago
    1. The property probably does not have a trigger, like "assert never {a && b}" - can you confirm that?
    2. In order to get the trace you need to add "define witness auto" or "define witness trace" before the prove command
    Jörg.
