  2. Functional Verification
  3. IMC Merging Issue of different test case of the same DUT...
  • Subscribers 67
  • Views 20074
Chetz
Chetz over 13 years ago
Dear All,
I'm trying to merge the coverage report of different test case of the same DUT but im getting an error saying.
Block coverage not merged - Checksum differs. Data is projected in to the target model.
The steps used for generating the coverage are:
1. Used the -coverage all option in the irun command "irun -coverage all"
2. Generated coverage for each test case in test_xxx folder.
3. Used the batch method to merge the each test case coverage into single coverage in coverage_log folder.
 Please refer the below error message and suggest me to slove the issue.
[bin]$ imc -batch merge_ncsim.cmd
imc: 11.10-p001: (c) Copyright 1995-2011 Cadence Design Systems, Inc.
Starting batch mode
imc> merge test_001/cov_work/scope/test/ test_002/cov_work/scope/test/ test_003/cov_work/scope/test/ test_004/cov_work/scope/test/ test_005/cov_work/scope/test/ test_006/cov_work/scope/test/ test_007/cov_work/scope/test/ test_008/cov_work/scope/test/ test_009/cov_work/scope/test/ test_010/cov_work/scope/test/ test_011/cov_work/scope/test/ test_012/cov_work/scope/test/ test_013/cov_work/scope/test/ test_014/cov_work/scope/test/ test_015/cov_work/scope/test/ test_016/cov_work/scope/test/ test_017/cov_work/scope/test/ test_018/cov_work/scope/test/ -out all -overwrite -metrics all
imc: *W,MGOPOW: The merge output directory cov_work/scope/all will be overwritten.
Merging IUS Coverage ...
Preparing target model ...
Reading model of primary run (test_001/cov_work/scope/test/) as initial model: test_001/cov_work/scope/icc_633670ed_00000000.ucm
Target model generated successfully.
Projecting ICC ucd data into the target model ...
test_001/cov_work/scope/test/:
test_002/cov_work/scope/test/:
    "tb_sum_int.INST_TESTCASE" to "tb_sum_int.INST_TESTCASE": Block coverage not merged - Checksum differs.
test_003/cov_work/scope/test/:
test_004/cov_work/scope/test/:
test_005/cov_work/scope/test/:
test_006/cov_work/scope/test/:
test_007/cov_work/scope/test/:
test_008/cov_work/scope/test/:
test_009/cov_work/scope/test/:
test_010/cov_work/scope/test/:
test_011/cov_work/scope/test/:
test_012/cov_work/scope/test/:
test_013/cov_work/scope/test/:
test_014/cov_work/scope/test/:
test_015/cov_work/scope/test/:
test_016/cov_work/scope/test/:
test_017/cov_work/scope/test/:
test_018/cov_work/scope/test/:
Writing output database cov_work/scope/all:
  Model: cov_work/scope/all/icc_633670ed_00000000.ucm
  Data : cov_work/scope/all/icc_633670ed_00000000.ucd
No Specman coverage databases found in the runs.
Total conflicts during target model creation: 0
Total items not merged                      : 17
List of conflicts non-merged items during target model creation report only when merge is run with "-message 1" option.
imc> load -run cov_work/scope/all
Successfully loaded run '/device/modules/sum_ctrl/verif/bin/cov_work/scope/all'.
imc> report -detail -type -html -all -out coverage_log/ -overwrite *
Output of report -html command sent to directory: coverage_log/
Thanks & Best Regards,
Chetz.
