  2. Functional Verification
  3. Command Line argument for Simulate systemverilog DPI using...
  • Subscribers 67
  • Views 17836
Command Line argument for Simulate systemverilog DPI using ncverilog?
Selvavinayak
Selvavinayak over 13 years ago
 Hi all,
   i am getting stuck on simulating systemverilog code in cadence... DPI related systemverilog code is running under some other tool I need to run that code in cadence.
   I compile systemverilog[*.sv] and *.CPP file using following command.
system verilog :
     ncverilog +define+$testcase+$mode +sv -f compile_list.f +ncdpiheader+dpi.h +elaborate +ncelabargs+-messages
     =>dpi.h is created...
 CPP:
     g++ -g -march=x86-64 -Wall -O2 -fPIC -I../cpp -include../dpi.h -I/`ncroot`/tools/inca/include -c $(sources_cpp) -DCADENCE
     g++ -march=x86-64 -shared *.o -o $(TARGET)
 $(TARGET) => shared library file *.so
Simulation:
    in simulation i need to include that above shared library *.so
    what is the command line  argument for simulate
     => ncsim +sv_lib=../*.so +access+r+w +ncsimargs+"-sv_root ./" .?....
note: I refered ncsim and ncverilog user guide which is in toolchain but i am not getting a solution...
Kindly help to direct me in right way for get a solution.....
selvavinayakam.na
  • tpylant
    tpylant over 13 years ago
    Are you getting an error with your command line?
    You can try "+sv_root=.. +sv_lib=*.so".
    Tim
  • Selvavinayak
    Hi Tim
    Thanks for your response,
        now i am able to run my code in cadence ncsim simulator using single step command [irun]...
    selvavinayakam.na
