  2. Functional Verification
  3. IFV assertion failure
  • Subscribers 66
  • Views 13921
Kris4Rad
Kris4Rad over 12 years ago
While running an IFV assertion check, the trace and trigger are showing the status "Pass" whereas the result is shown as "Fail".
 Please tell me where the issue could be?
  • maheshs
    maheshs over 12 years ago
    Hi, it seems the failure came from design itself. Please open CEX of the failed assertion and is should be able to show you why assertion failed. You can then debug the RTL logic accordingly.
    Mahesh Soni
  • StephenH
    StephenH over 12 years ago
    Trace and Trigger pass means that the tool was able to find at least one way to trigger the check and to complete the check. Basically these are coverage, telling you that the assertion hasn't passed vacuously.
    It's perfectly natural to have trace and trigger passing with a failing assertion, you should only worry about these if you get an assertion pass when the trigger or trace are failing.
