  2. Functional Verification
  3. Multi-Language ml_uvm for e_sv
  • Subscribers 67
  • Views 15884
Selvavinayak
Selvavinayak over 13 years ago
   for Initial Stage I just create Dummy Wrapper in UVM-SV for Checking purpose...
Below is my Dummy file test.sv
This file contain - sequence_item,driver,monitor,environement,top_tb,dut and interface...
*** => important things are in Bold letter...
`include "uvm_macros.svh"
interface dut_if;
  logic clk;
  logic [7:0] addr;
  logic [7:0] data;
endinterface
module dut(dut_if m_dut_if);
  import uvm_pkg::*;
  always@(posedge m_dut_if.clk)
  begin
    `uvm_info("", $sformatf("POSEDGE: DUT received addr=%d, data=%d",m_dut_if.addr,m_dut_if.data),UVM_MEDIUM)
  end
  always@(negedge m_dut_if.clk)
  begin
    `uvm_info("", $sformatf("NEGEDGE: DUT received addr=%d, data=%d",m_dut_if.addr,m_dut_if.data),UVM_MEDIUM)
  end
endmodule
package hello_pkg;
  import uvm_pkg::*;
  class hello_sequence_item extends uvm_sequence_item;
    `uvm_object_utils(hello_sequence_item)
    rand int addr;
    rand int data;
    constraint c_addr { addr >= 0; addr < 256; }
    constraint c_data { data >= 0; data < 256; }
    function new (string name = "");
      super.new(name);
    endfunction
    function string convert2string;
      return $sformatf("addr=%0d, data=%0d",addr,data);
    endfunction
    function void do_copy(uvm_object rhs);
      hello_sequence_item tx;
      $cast(tx, rhs);
      addr = tx.addr;
      data = tx.data;
    endfunction
    function bit do_compare(uvm_object rhs, uvm_comparer comparer);
      bit status = 1;
      $cast(tx, rhs);
      status &= (addr == tx.addr);
      status &= (data == tx.data);
      return status;
    endfunction
  endclass: hello_sequence_item
  typedef uvm_sequencer #(hello_sequence_item) hello_sequencer;
  class hello_sequence extends uvm_sequence #(hello_sequence_item);
    `uvm_object_utils(hello_sequence)
    hello_sequence_item item_h;
      super.new(name);
    endfunction
    task body;
      if (starting_phase != null)
        starting_phase.raise_objection(this);
      repeat(8)
      begin
        item_h = hello_sequence_item::type_id::create("item_h");
        start_item(item_h);
        if( !item_h.randomize() )
          `uvm_error("", "Randomize failed")
        finish_item(item_h);
      end
        starting_phase.drop_objection(this);
    endtask: body
  class hello_driver extends uvm_driver #(hello_sequence_item);
    `uvm_component_utils(hello_driver)
    virtual dut_if m_dut_if;
    function new(string name,uvm_component parent);
      super.new(name,parent);
    endfunction
    function void build_phase(uvm_phase phase);
      if( !uvm_config_db #(virtual dut_if)::get(this, "", "dut_if", m_dut_if))
        //`uvm_error("CONFIG", "uvm_config_db::get failed")
        `uvm_fatal("CONFIG",{"config must be set for : ",get_full_name(),".m_dut_if"});
    endfunction
    task run_phase(uvm_phase phase);
      forever
      begin
        seq_item_port.get_next_item(req);
        // Wiggle pins of DUT
        @(posedge m_dut_if.clk);
        m_dut_if.addr = req.addr;
        m_dut_if.data = req.data;
        `uvm_info("", $sformatf("DRIVER POSEDGE addr=%d, data=%d",m_dut_if.addr,m_dut_if.data),UVM_MEDIUM)
        @(negedge m_dut_if.clk);
        `uvm_info("", $sformatf("DRIVER NEGEDGE addr=%d, data=%d",m_dut_if.addr,m_dut_if.data),UVM_MEDIUM)
        seq_item_port.item_done();
      end
    endtask
  endclass: hello_driver
  class hello_monitor extends uvm_monitor;
    `uvm_component_utils(hello_monitor)
    int mon_addr;
    int mon_data;
    endfunction
        `uvm_error("", "uvm_config_db::get failed")
    endfunction
      forever
      begin
        mon_addr=m_dut_if.addr;
        mon_data=m_dut_if.data;
        `uvm_info("", $sformatf("MONITOR NEGEDGE addr=%d, data=%d",mon_addr,mon_data),UVM_MEDIUM)
        `uvm_info("", $sformatf("MONITOR POSEDGE addr=%d, data=%d",mon_addr,mon_data),UVM_MEDIUM)
        m();
      end
    endtask
    task m();
      `uvm_info(get_type_name(), "I am here", UVM_MEDIUM)
    endtask
  endclass: hello_monitor
  class hello_env extends uvm_env;
    `uvm_component_utils(hello_env)
    hello_driver driver;
    hello_sequencer sequencer;
    hello_monitor monitor;
    endfunction
      sequencer = hello_sequencer::type_id::create("sequencer",this);
      driver    = hello_driver::type_id::create("driver",this);
      monitor   = hello_monitor::type_id::create("monitor",this);
    endfunction
    function void connect_phase(uvm_phase phase);
      driver.seq_item_port.connect( sequencer.seq_item_export );
    endfunction
  endclass: hello_env
  class hello_test extends uvm_test;
    `uvm_component_utils(hello_test)
    hello_env my_env;
    endfunction
      my_env=hello_env::type_id::create("my_env",this);
    endfunction
      hello_sequence seq;
      seq=hello_sequence::type_id::create("seq");
      `uvm_info("", "Hello World_0", UVM_MEDIUM)
      if( !seq.randomize() )
      seq.starting_phase = phase;
      seq.start(my_env.sequencer);
      `uvm_info("", "Hello World", UVM_MEDIUM)
    endtask
  endclass: hello_test
endpackage: hello_pkg
module top;
  import uvm_pkg::*;
  import ml_uvm::*;     => ///For multi-Language interaction i am just import multi-language
import hello_pkg::*;
  dut_if dut_if1 ();
  dut    dut_m ( .m_dut_if(dut_if1) );
  initial
  begin
    dut_if1.clk = 0;
    forever #5 dut_if1.clk = ~dut_if1.clk;
  end
  initial
    begin
      uvm_config_db #(virtual dut_if)::set(null, "*", "dut_if", dut_if1);
      //uvm_top.finish_on_completion = 1;
      run_test("hello_test");
  end
endmodule
 if I run above test.sv in cadence simualtor with following command #! /bin/sh -f
IUS_HOME=`ncroot`
irun -access rw \
-uvmhome ${IUS_HOME}/tools/uvm-1.1 \
-uvmtop sv:hello_env \
test.sv
I am getting below error,
   UVM_FATAL test.sv(98) @ 0: hello_env.driver [CONFIG] config must be set for : hello_env.driver.m_dut_if
--- UVM Report catcher Summary ---
  anybody Guide me to Resolve this issue...
selvavinayakam.na
  • StephenH
    StephenH over 13 years ago
    You have a couple of issues at play here. Firstly, if using ML-UVM, don't execute run_test() from your SV code; this gets done automatically from the irun -uvmtop argument.
    Next, you need to pass the test class name to -uvmtop, not the env name.
    Another point if that the "dut_if" argument in your uvm_config_db calls should match the SV field name, so instead of dut_if, use m_dut_if.
    Finally, you have a race between your initial block that calls uvm_config_db::set() and the call to run_test() from the ML package.
    To avoid the race, it helps if you call the uvm_config_db::set() from your test base class's build_phase. We would usually not define the test in a package, and that lets you use the pointer to the interface instance directly.
    Here's a modification of your code and irun command that works.
    interface dut_if;
      logic clk;
      logic [7:0] addr;
      logic [7:0] data;
    endinterface
      import uvm_pkg::*;
      begin
      end
      begin
      end
    endmodule
    package hello_pkg;
      import uvm_pkg::*;
        rand int addr;
        rand int data;
          super.new(name);
        endfunction
        endfunction
          $cast(tx, rhs);
          addr = tx.addr;
          data = tx.data;
        endfunction
          bit status = 1;
          $cast(tx, rhs);
          return status;
        endfunction
          super.new(name);
        endfunction
        task body;
          repeat(8)
          begin
            start_item(item_h);
          end
        endtask: body
        endfunction
          if( !uvm_config_db #(virtual dut_if)::get(this, "", "m_dut_if", m_dut_if))
        endfunction
          forever
          begin
          end
        endtask
        int mon_addr;
        int mon_data;
        endfunction
        endfunction
          forever
          begin
            m();
          end
        endtask
        task m();
        endtask
        endfunction
        endfunction
        endfunction
      endclass: hello_env
        hello_env my_env;
        endfunction
        endfunction
          hello_sequence seq;
        endtask
    module top;
      import uvm_pkg::*;
      import ml_uvm::*;     ///For multi-Language interaction i am just import multi-language
      dut_if dut_if1 ();
      class actual_test extends hello_test;
        `uvm_component_utils(actual_test)
        endfunction
          uvm_config_db #(virtual dut_if)::set(null, "*", "m_dut_if", dut_if1);
          super.build_phase(phase);
        endfunction
      endclass
      initial
      begin
        dut_if1.clk = 0;
      end
    endmodule
     irun -access +rwc -uvmhome `ncroot`/tools/uvm-1.1 -uvmtop sv:actual_test ml.sv
  • Selvavinayak
    Thank you very much, StephenH
       your updated example code is working fine and its helpful for me to understand about ml_uvm package.
       and also I refer help from cdnshelp u previously mentioned... again thanks for your reply.....
    Thanks & Regards,
    selvavinayakam.na
