  2. Functional Verification
  3. Coverage results over the time (RTL)
  • Subscribers 67
  • Views 15598
GiuseppeDG
GiuseppeDG over 13 years ago
Is it possible to track the coverage results over the time? For bug detection, it is well accepted that the rate at which bug are detected approximates an exponential decay. That is at beggining is should be easier to detect bug, then it becomes more an more complicate. We can distinguish between easy and hard-to-detect bugs. The trends can be depicted in this chart:
Bug detection
  |--------- 100% ------------------------------
  |-----------------------------------> Time
 Can I register toggle or block coverage at RTL with timing information for printing a similar chart?
  • pcarzola
    pcarzola over 13 years ago
    Yes you can with Enterprise Manager.
    -Paul
  • GiuseppeDG
    Do you know if it is just a matter of flags to be passed to ncsc_run and then I have to open the coverage-result file in Enterprise Manager? Or do I have to create a specific testbench (e.g., UVM, e, ...)?
     Thank you.
  • pcarzola
    You won't have to modify your testbench but you will need to collect your runs into the groupings to reflect the simulations over time.
    You'll want to work with your local Application Engineer to get some guidance on this.
    -Paul
