  2. Functional Verification
  3. ncelab ncutilities E,BUILDF
  • Subscribers 68
  • Views 2999
lucacenzato
lucacenzato over 13 years ago
Hi all,
Switching from release 10 to 12.2, I've found some problem with testbench which uses nc utilities.
ncelab (version 12.2) with option "-update" exit with  :
ncelab(64): 12.20-s007: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
Updating: package NCUTILS.NCUTILITIES (AST)
/cadence/IS12.2/tools/inca/files/NCUTILS.src/ncutilities.vhd:
ncvhdl_p: *E,DLPAKW: Attempt to write package ncutils.ncutilities (AST)
into a read-only library.
         errors: 1, warnings: 0
ncupdate: *E,BUILDF: Rebuild of unit package NCUTILS.NCUTILITIES (AST) failed.
entity worklib.tb_ncutil (AST) is already up to date.
ncelab: *F,DLUPFL: Update failed for entity WORKLIB.TB_NCUTIL (AST)
(unable to update).
I didn't find clues on the web or in the docs,
Luca
  • tpylant
    tpylant over 13 years ago
    It sounds like the libraries weren't extracted after installation. Have the admin run the scripts in /cadence/IS12.2/tools/inca/files/install drirectory.
    Tim
  • lucacenzato
    Hi Tim,
    next monday I'll ask admin to check; at a first glance it seems that there aren't big difference in path
     /cadence/IS12.2/tools/inca/files/install/NCUTIL comparing to release 10.
    Moreover, without update option, elaboration step is succesful.
    Luca
  • melisanthi
    melisanthi over 13 years ago
    HELP!  I'm getting this same error when I changed to version 12.10.007.  I'm working in SimVision, however, and there is no "admin" here.  Just me!  I created a FIFO in SmartGen and I'm now getting the following errors when I try to simulate:
    ncvhdl_p: *E,DLPAKW: Attempt to write entity proasic3.vcc (AST) into a read-only library.
    ncupdate: *E,BUILDF: Rebuild of unit entity PROASIC3.VCC (AST) failed.
    I'd go back to using the older version but I was getting compilation errors concerning the "library proasic3" that was being referenced in the new FIFO.vhd file.  Any ideas on how to clear this hurdle?
  • melisanthi
    UPDATE:  It turns out that there is an admin here and that there was a problem with our compiled Actel 10.1-SP3 NC Sim libraries.  A recompilation resolved the issue.
