  2. Functional Verification
  3. DIVA LVS Problem After Installing Assura
  • Subscribers 67
  • Views 14819
eame
eame over 13 years ago
Hi, I'm a beginner and i'm trying to explain my problem as best i can. I use IC615 and Assura 41. After installing and putting Assura into my system (set environment variable ASSURAHOME) diva does not work properly. After i go from verify/LVS.., first there's some buttons missing from the diva LVS window, there're like half buttons missing from the window. The extracted view was matched with the schematic before. But after installing assura i could not use verify/LVS to match any cell. And when i ran lvs i get something like this:
 "Unrecognized input "No" in the netlist"
 In the netlist of the layout it says a bunch of
"No element format property found for element /+1924" "No element format property found for element /+1923"...
It's like the netlist could not be recognized any more by diva. I thought this is a problem caused by Assura. i deleted the environment variables(ASSURAHOME) to block assura. But the problem is still there.
I mean is it normal that after installing assra that diva changed? Or after installing assura all the diva rule file has to be converted to assura?
Thanks in advance
  • eame
    I think this is in the wrong category. I'll repost it in CUstom IC. Please bare with me because I couldn't delete this post.
