  2. Functional Verification
  3. Trace fail
  • Subscribers 67
  • Views 15748
Trace fail
Buvna
Buvna over 13 years ago
Im running assertions on IFV with witness check defined as trace. The trace fails and the assertion passes. What does this mean?
Thanks.
  • TAM1
    TAM1 over 13 years ago
    There are a couple of ways this can happen. They are based on the principle that an assertion "passes" if IFV cannot find a sequence in which the assertion reaches an error state.
     So, if you have an assertion that looks like "trigger_sequence |-> suffix_sequence", then the assertion will "pass" if the trigger_sequence can never occur. Since the trigger can't occur, the suffix doesn't need to be checked. This is by far the most common way to get the results you have described.
     You can check to see if the trigger is possible, given your constraints, by issuing the TCL command "define witness_check trigger".
  • Buvna
    Thanks for the reply.
    When I enabled changed witness to trigger, it failed too.
    This essentially means I needn't bother about this assertion right?
  • TAM1
    Well, I would worry about it. :-)
    When you  wrote the assertion you obviously thought that the trigger was possible and that you needed to check for certain behavior when it occurred. If IFV reports that the trigger is impossible you need to figure out what that means. Why can't the trigger occur? Did you write it correctly? Is there a bug in the DUT that makes behavior you expected to be legal impossible? Why did someone give you a specification describing behavior for conditions that can never be seen?
