  2. Functional Verification
  3. how to Simulate SystemC file...
  • Subscribers 67
  • Views 16713
Selvavinayak
Selvavinayak over 13 years ago
If i execute systemC file[test.cpp] with following command,
 irun -sysc test.cpp -lrt -sctop sc_main
   I am getting below error message,
 ld: cannot find -lsystemc_sh
collect2: ld returned 1 exit status
make: *** [/<....>/./INCA_libs/irun.lnx86.10.20.nc/librun.so] Error 1
ncsc_run: *E,TBBLDF: Failed to build test library
can any one give solution to overcome above Issue..
Selvavinayakam.NA
  • muffi
    muffi over 13 years ago
    The error suggests that the tool wasn't configured correctly after installation.
    During the configuration step that presents you with the license agreement, it requires you to type in "IAGREE"
    If you didnt accept to the license agreement then some of the key files in the installation will not be there.
    Please reconfigure your installation and make sure that you type "IAGREE" to the license agreement sub-step of configuration.
    You can configure the tool via InstallScape. In the InstallScape gui, there is an option named "Configure".
    You could also try configuring the product manually using the following steps:
    > cd <INSTALL_DIR>
    > ./tools/systemc/files/install/ncscKernel.ins
    > ./tools/systemc/files/install/ncscKernelGnu.ins
    When prompted, type "IAGREE" at the end of the license agreement.
    You will require full permissions on the machine where the tool is installed, to run these scripts.
    I hope this helps.
