  2. Functional Verification
  3. IFV run time errors
  • Subscribers 67
  • Views 16062
IFV run time errors
PRIYM
PRIYM over 13 years ago
This is the first time I am using IFV tool. Whenever I try to run it it returns with the following errors:
Error at line 1 of /afs/ece.cmu.edu/support/cds/share/image/usr/cds/incisiv-12.10/tools/ifv/files/OVL/VHDL/cds.lib for /afs/ece.cmu.edu/support/cds/share/image/usr/cds/incisiv-12.10/tools/ifv/files/OVL/VHDL/ACCELLERA:
Invalid path
Error at line 1 of /afs/ece.cmu.edu/support/cds/share/image/usr/cds/incisiv12.10/tools/ifv/files/OVLACCELLERA/VERILOG/cdsovlverilog.lib for /afs/ece.cmu.edu/support/cds/share/image/usr/cds/incisiv-12.10/tools/ifv/files/OVLACCELLERA/VERILOG/OVLVERILOG:
Invalid path
I have checked my file system and there is no ACCELLERA file. I don't understand why is it happening and how can I set it right. It will be really great if someone can direct me in the right direction.
  • JoergM
    JoergM over 13 years ago
    this looks like a installation configuration issue. I suspect you installed, but did not configure the Incisive installation. Please revisit the installation procedures and make sure you complete configuration.
    Joerg
  • PRIYM
    Thanks for the reply. I re-read the installation and configuration guide. I think I did all the required steps.
    For your reference I did the following steps;
    1. Settting enviornment variable for IFV_ROOT
    2.  source $IFV_ROOT/tools/bin/ifv_setup
    3. Setting path for CDS_LIC_FILE
    What could I have possibly missed??
    Priya
  • JoergM
    Hi Pryia,
    The steps you describe are the setup of your tool environment. But I suspect that the underlying tool installation is incomplete. Please start our installation software iscape and repeat the configuration step.
    Jörg.
