  2. Functional Verification
  3. Command Line option for Local Pulse Filtering
  • Subscribers 66
  • Views 13883
RoshanPaul
RoshanPaul over 12 years ago
Hi All,
 Goodmorning. I am trying  to find out an option for filtering pulse local to a module.
From docs, I see that, there are below command line options to filter pulse globally.
-pulse_e, -pulse_r, -pulse_int_e, -pulse_int_r
But globally enabling this option results in lot of warnings of type TRTIMING.
Is there a COMMAND Line option for the same purpose but to enable this locally to some module.
From document, I see that  there is a PATHPULSE specparam which could be added in specify block of desired module.
But, a command line option was a better option.
Roshan
