  2. Functional Verification
  3. SV Help ! how can dump the wave from class ?
  • Subscribers 67
  • Views 19333
phoenixson
phoenixson over 13 years ago
Hi, all
 Now I define a class ,and initiate it to a new class varible, I want to dump  some signals from it , how can I get that ?
  • Doug Koslow
    Doug Koslow over 13 years ago +1
    Hi, You simply need to probe the class variable in order to view its fields in the SimVision Waveform window. For example, using the following testcase: //test.sv module top; class c1; int i; endclass…
  • Doug Koslow
    //test.sv
    module top;
      class c1;
        int i;
      endclass
      c1 o1 = new;
      initial
      begin
        #50 o1.i++;
        #50 o1.i++;
        #50 o1.i++;
        #50 o1.i++;
      end
    endmodule
    Invoke irun with this command:
    irun test.sv -access +rwc -input input.tcl
    ...with an "input.tcl" file with the following contents:
    database -open waves -into waves.shm -default
    probe -create top.o1 -depth all -database waves
    run
    exit
    When simulation completes, you can invoke SimVision ("simvision waves.shm")
    and send the class variable "top.o1" to the Waveform window.  Expand "o1" in
    the Waveform window and you can see the value of "o1.i" over time.
    Good luck.
    - Doug
  • phoenixson
    okay, I got it ,thanks a lot for your patient reply.
