  2. Functional Verification
  3. Simvision list view
  • Subscribers 67
  • Views 19795
Simvision list view
IHR01
IHR01 over 13 years ago
Hi all,
In simvision is there a way to display signals in a 'list view'?, that is,  each row represent a time value at which a signal changed and each column is a signal.
I.
  • Doug Koslow
    Doug Koslow over 13 years ago
    There is no list view window per se in SimVision.  However, you can export a .CSV file with a table in the form you describe either in SimVision using the "File->Export..." menu or using the "simvisdbutil" command, and then import it into Microsoft Excel or any .CSV reading tool.
     Good luck.
    - Doug
  • IHR01
    Thanks Doug,
    I see that by using File->Export it does not allow me to use the mnenonic map that I've created for a particular signal. Is this a limitation?
    -I.
  • Doug Koslow
    That is correct.  Since mnemonic maps are applied to individual waveform traces, and in fact two different waveform traces of the same signal could have different maps applied, the maps do not affect an export of database signals.
    Thanks.
    - Doug
