  2. Functional Verification
  3. reinvoking from the tcl shell
  • Subscribers 67
  • Views 16348
freitas
freitas over 13 years ago
I'd like to reinvoke the simulation using a tcl script. Is this possible? What's the tcl command to re-invoke the simulation?
Actually, I would like a script that runs a preamble command to update the simulation options contained in the irun.f file before re-starting the simulation. That would allow me to re-start the simulation with new options without leaving simvision.
Is this feasible?
thanks
  • Doug Koslow
    Doug Koslow over 13 years ago
    Yes, this is possible.
    Since reinvoke is a SimVision operation, you need to execute SimVision commands in order
    to execute it.
    Here is a set of commented SimVision commands to do this, including copying over
    a modified irun.f file.  You could define a custom toolbar button to invoke these commands.
    # Need to disable opening the reinvoke dialog when reinvoking via a script.
    preferences set prompt-on-reinvoke 0
    # Replace these file names with yours.
    set from_file "irun_mod.f"
    set to_file "irun.f"
    exec cp -f $from_file $to_file
    # reinvoke via the Design Browser.  (Assumes this window is still available.)
    window invoke "Design Browser 1" Simulation>ReinvokeSimulator
    # Set the preference back.
    preferences set prompt-on-reinvoke 1
    Good luck...
    - Doug
  • freitas
    It works as a charm! Thanks a lot!
