  2. Functional Verification
  3. i want to check these assume properties are correct
  • Subscribers 66
  • Views 14386
BharathECE
BharathECE over 12 years ago
I wrote some of the assumptions in my fifo design and now  the assertion passing in my design.Before assemptions that assert property was failing.
assumptions are as below:
///Assumtion to check underflow:
 assume_underflow :assume property(assume_property_underflow) $info("assumption holds"); else $error("Assumption failed underflow");
property assume_property_underflow;
  @(posedge clk)
  (!read && empty); /*$info("Assumption undeflow holds");
                                          else $error("Assertion underflow does not hold");*/
endproperty
///Assumtion to check overflow:
 assume_overflow :assume property(assume_property_overflow) else $error("Assumption failed overflow");
property assume_property_overflow;
  @(posedge clk)
  ((!write or !read) and full);  /*$info("Assumption overflow holds");
                                          else $error("Assumption overflow does not hold");*/
endproperty
Please see these logics are correct?
