  2. Functional Verification
  3. Stept through UVM code
  • Subscribers 67
  • Views 19393
Tudor Timi
Tudor Timi over 12 years ago
I'm trying to step through the SV UVM library code, but I just can't manage. I tried the built in library in IUS and also a version downloaded from Accelera. Both setups have -linedebug on the command line. When trying with the built in one, it says it was not instrumented for line debugging. The Accellera one lets me put breakpoints, the simulator stops there, but it doesn't show the execution point in the source browser (it just mentions in the console that it stopped at the specific line).
Is there something I'm missing?
Thanks and best regards,
Tudor
  • hannes
    hannes over 12 years ago
    Hi Tudor, try with the -uvmlinedebug option of irun: " -uvmlinedebug Enable single-stepping through UVM functions and tasks. By default, -uvm -linedebug does not apply the -linedebug option to the compilation of the UVM package. This means that when you are debugging your code, single-stepping through the UVM content is not enabled. Include the -uvmlinedebug option if you want to single-step through the UVM content to debug UVM code. This option forces the UVM package, and all other HDL files specified on the command line, to be compiled with line debug capabilities. " Regards, -hannes
  • Tudor Timi
    Thanks a lot for the quick answer! It works to set breakpoints in the built in UVM code, but it's still not showing me the execution point.
  • hannes
    The execution may be in a different scope. Are you using -linedebug as well? In general if everything is traced and you are stopped, you can click on the yellow arrow in the debugger to get to the current execution point. -hannes
  • Tudor Timi
    Hi again, It seems like it was a scope issue. It works now. Thanks a lot for the help!
