  2. Functional Verification
  3. e testflow
  • Subscribers 67
  • Views 15955
e testflow
myonlyscreen
myonlyscreen over 12 years ago
I am using e testflow, and encountering an interesting case that i would like to share and get your feedbacks.
I have an environment "A" with tf_domain == domain_a.
Under this  environment i am instantiating an environment "B" which is testflow unit and have 2 sequence drivers which are also testflow units.
According to the Cadence test flow document, if the tf_domain field is untouched, it is determined to be (with soft constraint) to be the same as the nearest enclosing testflow unit, if there isn't such  tf_domain is set to DEFAULT.
However, what i see is:
env_b.tf_domain = domain_a
env_b.seq_driver_1.tf_domain = domain_a
env_b .seq_driver_2.tf_domain =DEFAULT
How come the second sequence driver didn't got the same tf_domain value like the other units?
Moreover, the tf_domain field is declared as const, thus can not be changed after generation.
I will be happy to hear your feedbacks.
  • hannes
    hannes over 12 years ago
    I've create a small testcase to try and reproduce your issue. However (as so often) it works fine here. I'm using 13.10.010-s and I only constrain the env tf_domain. All sub units (which are all testflow_units) inherit they tf_domain setting from the enclosing unit. If you want to force the tf_domain, you can use constraints, i.e.:
    (in the env)
    keep seq_driver_2.tf_domain==tf_domain;
    -hannes
  • myonlyscreen
     Hi Hannes,
    First, thanks for your quick  response, I have tried your suggestion and it fix the problem.
    Moreover, even constraining only the env "B" solve it.
    It seems like the generation solver somehow ignored the soft constrain.
    The explicit keep on the tf_domain solve this problem.
    While we are talking on e testflow I want to ask one more question.
    Does the usage of testflow make the e objection mechanism redundant  ?
    What are Cadence recommendation on this subject ?
    E.M.
  • hannes
    Hi E.M.
    in general testflow is very helpful in phaseing you environment. However, there are cases when it may be helpful to still use the TEST_DONE objection. For example there may be other units/UVCs which don't use testflow, or multiple unrelated domains. A good approach would be:
    - in the phase TCM of the first phase (ENV_SETUP) – raise_objection(TEST_DONE)
    - as last thing of the last phase (FINISH_TEST) - drop_objection(TEST_DONE)
    -hannes
