  2. Functional Verification
  3. How to manually flush display message buffer to console...
  • Subscribers 67
  • Views 20848
How to manually flush display message buffer to console?
bdel
bdel over 12 years ago
I have a few functions that take a long time to compute results. I'm trying to debug any performance problems. I know about the profiler and this has been of some use. No need to suggest this.
I'd like to print something on each iteration of the computation so I can get a real time sense for how the computation is progressing via live messages in the SimVision console window. However, Simvision seems to be buffering my $write(".")/$display() message until the end of the time slot.
   protected function void process_streams(adc_stream streams[]);
    for (int i = 0; i < streams.size(); i++) begin
      for (int ii = 0; ii < streams[i].num_samples(); ii++)
        process_sample(streams[i].m_adc_samples[ii].sample);
      $write(".");
    end
    $display();
  endfunction
I see no dots printed to the console for minutes and then all of a sudden they all show up.
Is there a SimVision option or command that'll cause messages to immediately be printed to the console window?
Ben
  • muffi
    muffi over 12 years ago
     You can try using the -unbuffered switch.
    > ncsim | grep -i unbuffered
            -UNBUFFERED                      -- Do not buffer output
  • bdel
    This worked. Thank you.
  • Arpan Vyas
    Arpan Vyas over 7 years ago in reply to muffi
    Is there a simulator command to force flushing the buffer on executing that? I do not want to impose heavy performance penalty by using the unbuffered option.
  • StephenH
    StephenH over 7 years ago in reply to Arpan Vyas
    If you pause the simulator then it should flush the buffers. There isn't a command that you can call to do it.
