  2. Functional Verification
  3. Using variables within range repetition expression in e
  • Subscribers 67
  • Views 15200
myonlyscreen
myonlyscreen over 12 years ago
 Hi.
I am facing some problems with using var in  range repetition expression.
I have the next code :
a : unit;
b : uint;
keep b == a + 1234;
event e1;
event e2;
expect {@e1;[a]*@clk} => @e2 ; //  <== this works !
 expect {@e1;[a..b]*@clk} => @e2 ; //  <== this doesn't work !
I am geting the next error :
 *** Error: first match variable repeat can only be used inside a sequence
Why ? does cadence supports such usage of the range repetition expresion ?
How do you recomend to workaround this problem ? (well beside the obivuos solution to replace it with TCM).
E.M.
  • hannes
    hannes over 12 years ago
    if you have a first match variable repeat ([a..b]*TE) it needs to be followed by something else (some successor event), e.g:
    expect {@e1; [a..b]*@clk; <some-other-temporal-exp>} => @e2;
    Btw. [a..b]*@clk succeeds (first match) at [a]*@clk, so the first expect and the second expect you wrote are the same.
    Maybe you wanted to express something else? There is also a true match repeat (~[..]*TE).
    -hannes
  • myonlyscreen
    Thanks, for clarifying this issue.
    It does make a lot of sense to add another TE after the range repetition, in-order to avoid getting match on [a]*clk .
    Thanks again,
    E.M.
