  2. Functional Verification
  3. What's the difference between -seed and -svseed in irun...
  • Subscribers 66
  • Views 12872
What's the difference between -seed and -svseed in irun?
archive over 12 years ago
There are two options to control random seed when using irun: -seed, -svseed.
It seems that these two options is doing the same thing: set a random seed to RNG. And I tried many times, I can't find difference between these two options. Both can be used to control Verilog/SystemVerilog randomization, for example:
-seed 123
-svseed 123
-seed random
-svseed random
So, what's the difference between these two options?
Thanks!
  • hannes
    hannes over 12 years ago
     Regarding irun, one thing which is useful is "irun -helpall | grep <word of interest". So irun-helpall | grep seed gives:
      -seed <seed>               Set the seed value for SystemVerilog and Specman
      -snseed <seed>             Pass seed value to Specman
      -svseed <seed>             Set SystemVerilog default RNG seed
    Numbers are seeds, "random" will be randomly generated seeds.
    -hannes
     Hi, Hannes:
    I know these descriptions given by irun, but I'm still not clear about what's the basic difference between "seed value for SystemVerilog" and "SystemVerilog default RNG seed". It seems that both "-seed random" and "-svseed random" can work when do simulation. Right?
  • hannes
    yes, that is correct. There is no difference between -seed and -svseed if you have a SystemVerilog testbench. Since IES also handles e testbenches, you have 2 switches to control them individually (-svseed/-snseed) and one which applies to both. This should give you all the flexibility you need.
