  2. Functional Verification
  3. Excluding Toggle coverage
  • Subscribers 67
  • Views 18259
Kiranreddi
Kiranreddi over 11 years ago
Hi All,
I am doing coverage part for my subsytem . I am using "set_toggle_excludefile" in my .ccf at the time of Elab . I am using patterns , so it is excluding some signals which are covered .i want to exclude only those which are not covered .
 I am using 12.2 version , ICCR. Please let me know any switch to exclude only uncovered toggles.
 Regards
Kiran
  • PraveenC
    PraveenC over 11 years ago
    Hi Kiran,
    Toggle exclusion through CCF is an elaboration (pre-simulation) step. Coverage tool does not sample excluded signals. On the other hand, the coverage can be known only after simulation. So, set_toggle_exclude is not the right thing to do in your case. You should try analysis time refinement to exclude uncovered signals.
    Praveen
