  2. Functional Verification
  3. CPF Simulations: Excluding PSL vunits
  • Subscribers 67
  • Views 15266
moogydmaxim
moogydmaxim over 12 years ago
I have a PSL vunit attached to my top level module (via PROPDIR), and this vunit contains some signals to implement some simple modelling.
The top level module is in a switchable power domain, and at the moment, when the power is removed, the PSL vunit is also "turned off". Are there any available options that exclude PSL vunints from CPF simulations?
FYI - the design language is VHDL and 13.20-p002
Steven
  • StephenH
    StephenH over 12 years ago
     Hi Steven.
    I'm not sure what you mean by "exclude PSL vunits from CPF simulations". Do you simply want to not simulate the PSL if you're running with CPF? Or do you want to keep the PSL active during power shut-off?
    Assertions can be turned off completely with the Tcl command "assertion -off -all". This may not be ideal as disabling the assertions might hide some bug related to mistakes in the CPF, even if non-CPF sims are functionally correct.
    I don't think there's any point in keeping PSL active if it's in a switchable domain that's off, since all the signals will be corrupted to X during shut-off.
