  2. Functional Verification
  3. get an error using 3 steps DPI C to simulate systemveri...
  • Subscribers 68
  • Views 19695
get an error using 3 steps DPI C to simulate systemverilog
jbriquet
jbriquet over 12 years ago
Hello all,
I want to call a C function within my systemverilog file using DPI C. I have tried the one step (irun -sv hello.c hello.sv )and it worked very well. But the thing I want to do is to create my own shared object .so, to do this I have tried a 3 steps methodology (ncvlog ,ncelab and ncsim) but it failed when I want to simulate it.
I got this message : ncsim: *F,NOLWSV: Searching for import subroutine "print" in default library libdpi. Unable to load the default library libdpi.OSDLERROR: ./libdpi.so: only ET_DYN and ET_EXEC can be loaded.
Please find in this following paragraph all my files and script to do this.
Thank you by advance,
 Jean-Pierre
 /////// top.sv
module top;
bit clk,rst;
helloworld U0(.clk(clk),.rst(rst));
////// reset
initial begin
rst=1;
#15;
rst=0;
end
///// clock
initial begin
clk=0;
#5;
forever begin
#5 clk=~clk;
end
end
endmodule
module helloworld(clk,rst) ;
input clk;
input rst;
bit clk, rst;
import "DPI-C" context function void print();
always @( posedge clk ) begin
$display("hello world");
        print();
end
endmodule
/////// hello.c
#include <stdio.h>
//#include <vpi_user.h>
//#include "svdpi.h"
void print()
 { printf("helloworld from C \n");}
/////// cds.lib
DEFINE lib ./lib1
/////// run using irun ( This solution works !!! ) But I want to create manually my shared object
irun -cdslib cds.lib -sv test.c test.sv
//////// run using NC-Verilog ( This solution doesn't work )
ncvlog -cdslib cds.lib -messages -sv top.sv -work lib
ncelab -messages -access +RWC lib.top
gcc -fPIC -shared -o libdpi.so test.c -I/pkg/cadence-incisiv-/13.20.003/i686-linux/tools/inca/include/ -m32 -c
ncsim -messages lib.top
///////  script report
...helloworld_verilated/test 600$ ncvlog -cdslib cds.lib -messages -sv top.sv -work lib
ncvlog: 13.20-s003: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
file: top.sv
        module lib.top
                errors: 0, warnings: 0
        module lib.helloworld
...helloworld_verilated/test 601$ ncelab -messages -access +RWC lib.top
ncelab: 13.20-s003: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
        Elaborating the design hierarchy:
                Caching library 'lib' ....... Done
        Building instance overlay tables: .................... Done
        Generating native compiled code:
                lib.helloworld:module <0x7028777f>
                        streams:   1, words:  1182
                lib.top:module <0x77267332>
                        streams:   2, words:   196
        Building instance specific data structures.
        Loading native compiled code:     .................... Done
        Design hierarchy summary:
                             Instances  Unique
                Modules:             2       2
                Registers:           2       2
                Scalar wires:        2       -
                Always blocks:       1       1
                Pseudo assignments:  2       2
        Writing initial simulation snapshot: lib.top:module
...helloworld_verilated/test 602$ gcc -fPIC -shared -o libdpi.so test.c -I/pkg/cadence-incisiv-/13.20.003/i686-linux/tools/inca/include/ -m32 -c
...helloworld_verilated/test 603$ ncsim -messages lib.top
ncsim: 13.20-s003: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
Loading snapshot lib.top:module .................... Done
  • FlyingHeart
    FlyingHeart over 12 years ago
     You need to use ncsim -svlib lib_name to load the dpi library generated by gcc, otherwise, the link process will report error
  • jbriquet
    Thank you, but i have used the simple way to do it using irun . But i have a question, is it possible to load several shared object and not only using the default "libdpi.so" ? because i have several shared object corresponding to a function, and i want to call several function from different shared object ...
    Is it possible to do this ?
    thank you by advance,
    Sincerely,
     Jean-Pierre
  • FlyingHeart
    In fact, you can generate multiple librires and use multiple -svlib lib_name to load multiple libraries and use different functions in irunto realize your idea.
