  2. Functional Verification
  3. step simulation
  • Subscribers 67
  • Views 14514
step simulation
sebgimi
sebgimi over 12 years ago
Hi all,
I'm stuck on a simple issue but can't get out of it: I would like to generate severals waveform signals for my future testbench but the frequency of my signals are not correct.
Below is the code I want to simulate:
library ieee;
use ieee.std_logic_1164 .all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.math_real.all;
entity triangle_generator is
 generic(AMP: real;
  OFFSET: real;
  FREQ: real;
  PHASE :real);
 port(wave1: out real);
end triangle_generator;
architecture archi of triangle_generator is
signal tmp1 : real := 0.0;
begin
 P1:process
 constant delta   : real := 1000.0e-12;
 constant fin  : time := 1000 ps;
 variable angle   : real := 0.0;
 variable t    : real := 0.0;
 variable PHASE_RAD : real := 0.0;
 begin
   PHASE_RAD := (math_2_pi * PHASE)/360.0;
  loop
   angle   := math_2_pi * FREQ * t;
   t := t + delta;
   tmp1 <= OFFSET+(AMP/2.0)*(2.0/math_pi)*arcsin(sin(angle));
   wait for fin;
  end loop;
  wait;
 end process P1;
 wave1 <= tmp1;
end archi;
When I simule this code with FREQ=100 000 000 Hz I get the waveform in attachment, not really what I wanted. So I was thinking, if I write delta = 1000.0e-15 maybe it will be right, but absolutly not. When I change the value of delta, the frequency of the waveform is wrong.
So can you help me to get through this please?
