  2. Functional Verification
  3. Irun : Load several shared object
  • Subscribers 68
  • Views 16766
jbriquet
jbriquet over 12 years ago
hello everyone,
I have a question about DPI-C , i know i can load a shared object using irun, even if you need to call it libdpi.so to load it . But I want to load several shared object and not only using the default "libdpi.so" ? because i have several shared object corresponding to a function, and i want to call several function from different shared object ...
Is it possible to do this ?
thank you by advance,
Sincerely,
 Jean-Pierre
  • Tudor Timi
    Tudor Timi over 12 years ago
    Yes, you can. The following is an excerpt from the manual:
    You can specify multiple shared objects by using multiple options. For example, the following command will load /x/y/mylib1 and ../mylib2 in multistep mode.
    % ncsim -sv_root /x/y -sv_lib mylib1 -sv_root ../ -sv_lib mylib2 snapshot
    or in single-step mode:
    % irun -sv_root /x/y -sv_lib mylib1 -sv_root ../ -sv_lib mylib2 files
  • jbriquet
    Thank you , it works very well. Sincerely, Jean-Pierre
