  2. Functional Verification
  3. Error on CLSMIP
  • Subscribers 66
  • Views 15424
Error on CLSMIP
DesignVerif
DesignVerif over 11 years ago
Hi
I am new to UVM and I am getting following error.
  Can anybody please help me out
  my_sequencer#(my_trans) sequencer
  ncvlog: *E,CLSMIP (./sv/my_agent.sv,25|34): Too many class instance parameter assignments.
Thanks in advance
  • muffi
    muffi over 11 years ago
    Assuming you are trying to define the sequencer handle, it should be:
        my_sequencer sequencer;
  • DesignVerif
    Thanks it did work But for understanding , does it tell that my_trans is transaction being used in my_sequencer. Also in some example I found out that syntax is given as below. my_sequencer#(my_trans) sequencer Can you please do let me whats the difference between above declaration and my_sequencer sequencer declaration
  • muffi
     When you define your component like this:
        class mysequencer #(type X=int, Y=real) extends uvm_sequencer #(myobj);
    It means that your object or component is parameterized. In this case you will create a handle like this:
         mysequencer #(int,string) foo = new();
    You provide a type parameter for X and Y. Not myobj.
    When you extend your component like this:
        class mycomp extends uvm_sequencer #(myobj)
    It gives you a built in handle called "req" which you can use for referring to your transaction object. #(myobj) is the type parameterization for the transaction.
    I hope this is clear.
  • DesignVerif
    Thanks ,
    Yeah its clear.
