  2. Functional Verification
  3. Passing parameters form verilog to systemC
  • Subscribers 67
  • Views 15312
jbriquet
jbriquet over 12 years ago
I want to call a systemC function in a Verilog shell using a wrapper, and I want to pass parameters from verilog to systemC, using "ncsc_get_param" in systemc side.
But I have a problem, because it is necessary to put parameters in the verilog wrapper, whereas I want to put them in a higher hierarchy ...
Please tell me if that i want is possible or not ?
Sincerely , jean-Pierre
  • jbriquet
    I have also noticed when I simulate only verilog wrapper and systemc module, I can see parameters on the schematic, but when I add a systemVerilog shell which calls the wrapper, parameters dissapears .... I think there is a kind of mask on the systemc module ... Can someone explain me this bthing . Thank you very much
