  2. Functional Verification
  3. Whether DPI - C functions can be used in the environment...
  • Subscribers 68
  • Views 2447
Whether DPI - C functions can be used in the environment where the top is in C.
Vimala
Vimala over 12 years ago
I have created a simple example for dpi functions. Below is the code:
CODE: C_file.c
#include "stdio.h"
#include "svdpi.h"
//int main()
extern void export_func(void);
void import_func()
export_func();
CODE: SV_file.sv
module sv_file;
export "DPI-C" function export_func;
import "DPI-C" context function void import_func();
function void export_func();
$display("SV: Hello from SV ");
endfunction
initial
begin
import_func();
end
endmodule
I am running the code with the command,
irun –sv sv_file.sv c_file.c
The dpi functions are working fine as expected.
But this code is without main() function. When I try running the code with main function, the sv code is not able to find the import_func definition in C.
1. So I wanted to know whether dpi functions can be used in an environment where we have only C testcases instead without sv testcases (ie) C is in the top of the environment and execution starts and ends in C.
2. And, I am not able to run the code when I am trying to use only the export function (ie) calling the C-defined function in SV. Is it possible to use only the export function without import?
Your help will be very useful for me. Thank you.
  • StephenH
    StephenH over 12 years ago
    Your C code cannot define main(), because there can only be one main() in a C program, and that belongs to ncsim! The simulator main() has to be in control of the simulation, and your DPI-C code can only be a slave to the simulator.
    Whatyou probably need to do is adapt your C tests so that the bus accesses into the RTL do via function calls like write_bus() and read_bus() which map onto Verilog tasks that actually do the pin-wiggling. You C test can't have a main() so you could call it something else like c_test() and DPI-import that into SV, so that SV can initiate the C test via "initial c_test();" os similar...
  • arnabd88
    arnabd88 over 11 years ago
    We have a C++ simulated processor model and attempting to plugin rtl interconnect between the cores and cache interface using dpi.
    However, if the main is controlled by ncsim, it doesn't seems C can reside as the top module.
