  2. Functional Verification
  3. Black boxing issue in IFV
  • Subscribers 66
  • Views 14124
niraj10
niraj10 over 11 years ago
I am facing problem while black boxing to end-IPs. The one IP contains signal which helps to start the system. So, I can't do black box to it. Still I want to check connectivity between those two IPs. What should I do?
  • StephenH
    StephenH over 11 years ago
     The connectivity app is only checking the physical connections between the IPs, not the functionality of the IPs, so you should not need to initialise / reset anything. To give an example: to check the DDR IP is connected correctly to the pads, IFV is only checking the wiring so that DQ[0] on the IP connects only to padDQ0. IFV is not testing whether the IP block drives any part of the DDR protocol.
