  2. Functional Verification
  3. Functional Coverage Question
  • Subscribers 68
  • Views 17651
ashfaqh
ashfaqh over 12 years ago
 I have 2 coverpoints.
 Each coverpoint has auto generated bins as well as user-defined bins.  In pseudo-code, I will describe them as follows:
 cp1:
     auto_bins,
     userdefined_bin0, userdefined_bin1 ;
cp2:
     auto_bins,
     userdefined_bin2, userdefined_bin3 ;
Now, I want to cross cp1 and cp2.  But, in that cross-coverage, I am only interested in crossing the userdefined bins and not the auto_bins.
cp1_x_cp2:
cross cp1, cp2 {
    userdefined_bin0 intersects with userdefined_bins_2, 3 ;
    userdefined_bin1 intersects with userdefined_bins_2, 3 ;
    **************** This is being achieved but the auto bins are also coming into play.
     *************** How do I ignore the auto bins??
 ashfaqh
  • Tudor Timi
    Tudor Timi over 12 years ago
    I assume this is SystemVerilog. For ignore bins in cross coverage have a look at this site:
     http://www.asic-world.com/systemverilog/coverage20.html
  • StephenH
    StephenH over 12 years ago
    Can you give us a more concrete example? I don't understand what you mean by auto bins, since as soon as you define your own bins the tool won't create auto bins in the coverpoints.
    Inside the cross, you can get rid of the auto bins by using the Incisive coverage control command: "set_covergroup -cross_auto_bin_max_default_zero" which needs to go in the coverage control file, passed to irun or ncelab via the -covfile option.
    Here's a small example adapted from the LRM, maybe you can tweak it to show us what you're seeing? In Incisive 13.20 this runs and does not produce any auto bins.
    module test;
    bit [7:0] v_a, v_b;
    event clk;
    covergroup cg @(clk);
      a: coverpoint v_a {
        bins a1 = { [0:63] };
        bins a2 = { [64:127] };
      b: coverpoint v_b {
        bins b1 = {0};
        bins b2 = { [1:84] };
      c : cross a,b {
        bins c1 = binsof(a.a1) || binsof(b.b1);
        bins c2 = binsof(a.a2) || binsof(b.b2);
    endgroup
    cg cgi;
    initial
    begin
      cgi = new;
      for(v_a=0; v_a<255; v_a++)
        for (v_b=0; v_b<255; v_b++)
        begin
          #1 ->clk;
        end
    end
    endmodule
