  2. Functional Verification
  3. Breakpoints in simvision(Incisiv Simulator)
  • Subscribers 67
  • Views 3694
subrahmanya
subrahmanya over 12 years ago
I  started using simvision(Incisiv Simulator) in my project recently. I have set few breakpoints in few files. Is there a way to save the breakpoints that I have marked in this run, so that I can load the same breakpoints in some later run? (This will be very handy in debugging process)
Any inputs  will be of great help.
Subrahmanya
  • hannes
    hannes over 12 years ago
    In the GUI menu there is an option under "File" called "Save Command Script ..." which will save all the current settings, including break points. You can restore that script during subsequent runs ("Source Command Script").
    -hannes
  • subrahmanya
    Thank you Hannes. I was thinking of that option, but was not sure. Thanks for the quick help. :)
