  2. Functional Verification
  3. Setting vhdl tb generic using irun command
  • Replies 8
  • Subscribers 68
  • Views 22406
itsonlyme
itsonlyme over 12 years ago
Hi all,
I've got a problem. In my tb I've got a generic:
        G_WAVEFORM_TYPE : string := "xxx"
and i'd like to change "xxx" to "yyy" using irun "start.f" file, but i can't
-mess -v93 -assert ../src/dut.vhd ../src/tb.vhd -generic "tb.G_WAVEFORM_TYPE => "yyy""
or in other file:
-top tb -access rwc -defparam tb.G_WAVEFORM_TYPE="yyy" -nowarn CUDEFB
doesn't work. Could you  tell me how to set a tb (vhdl) generic from *.f file using irun -f and what is the correct command to do it?
John.
  • Tudor Timi
    Tudor Timi over 12 years ago
    -defparam is for Verilog parameters. There is a -generic switch that can handle top level VHDL parameters.
  • itsonlyme
    OK. :)
    In which place i should use it - compilation line or elaboration? And what is the format of argument if generic is a string?
    or
    -generic "tb.G_WAVEFORM_TYPE => yyy"
    or
    -generic tb.G_WAVEFORM_TYPE = "yyy"
    John.
  • StephenH
    StephenH over 12 years ago
     -generic is the right switch but you may need to use colons not dots.
    From the docs:  irun -generic "vlog_top:vhdl_inst1:gen => 4" top_level_design_unit
    So for you: irun -generic 'tb.G_WAVEFORM_TYPE => "yyy"'
  • StephenH
    It's an elaboration switch. Your quotes are wrong, use this:
  • itsonlyme
    My run.f file:
    // Compile the VHDL files
    // Information for elaboration
    -top tb -access rwc -generic 'tb.G_WAVEFORM_TYPE => "yyy"' -nowarn CUDEFB
    // Set up the simulation
    -input ../src/dir_ncsim/setup.tcl
    // exit simulation at the end
    -exit
    Used command:
    irun -64BIT -f ../src/dir_ncsim/run.f
    Return code:
    irun: *E,FMUK: The type of the file (=>) could not be determined.
    irun: *E,FILEMIS: Cannot find the provided file =>.
    irun: *E,FMUK: The type of the file (yyy') could not be determined.
    irun: *E,FILEMIS: Cannot find the provided file yyy'.
    yyy' should be a string value not a name of file. And what does ' mean? Any ideas? When I do not set generic, simulation working fine, but for default "xxx" value.
    I'm using INCISIV131.
    Greetings,
    John.
  • StephenH
     I don't know which version you're running but maybe irun isn't liking the single quotes. I built a small example for you, untar it and run the RunMe.sh to see how it works - the test should print "irun" to show the generic got the command-line value instead of the "vhdl" value that's set in the instantiation.
    generic.tar
  • TAM1
    TAM1 over 12 years ago
     Here's Stephen's entry:
    -generic "tb:u_dut:str=>\"irun\""
    It seems like every Unix shell and the irun -f file processor interprets quote characters differently. So adding escape characters helps nail down exactly what you meant to say.
  • itsonlyme
    -top tb -access rwc -generic "tb:G_WAVEFORM_TYPE=>\"yyy\"" -nowarn CUDEFB
    It's working now, thank you very much. :)
    John.
