  2. Functional Verification
  3. vManager Failed: Unexpected error ( Out of memory )
  • Subscribers 67
  • Views 19958
JennyYang
JennyYang over 12 years ago
When I run following command to collect coverage  (There are 2000  vsof files)
emanager -coverage -vsof " ./covwork/irun/*/*.vsof " &
I got the Error: vManager Failed: Unexpected error
The reason is Out of memory .
When I run coverage follow. I always get 2 problems:
(1) vManager Failed: Unexpected error   ( Out of memory )
(2) If no error, it is very slow and will consume much of memory.
How to solve upper problems.
Here are more log info:
Reading EManager configuration...
Doing EManager setup...
On-the-fly GC, current size is 2569369600 bytes (including 323404 known free)
Done - total size of reachable data is 79912192 bytes (plus 2467005536 free).
On-the-fly GC, current size is 3124511600 bytes (including 547645728 known free)
Done - total size of reachable data is 83085120 bytes (plus 3022911368 free).
On-the-fly GC, current size is 3198727704 bytes (including 628465380 known free)
Done - total size of reachable data is 85586128 bytes (plus 3093959788 free).
On-the-fly GC, current size is 3254023348 bytes (including 683430808 known free)
Done - total size of reachable data is 87813604 bytes (plus 3147439360 free).
Memory accounting is not enabled. Set the environment variable SPECMAN_MEMORY_ACCOUNTING to enable it
configuration options for: memory
        -automatic_gc_settings         =      STANDARD
        -optimal_process_size          =      3154116608
        -notify_gc_settings            =      FALSE
        -gc_threshold                  =   1393665248
        -gc_increment                  =  0
        -print_msg                     =  TRUE
        -print_otf_msg                 =   TRUE
        -retain_printed_structs        = TRUE
        -retain_trace_structs          = FALSE
        -max_retained_structs          =      0
        -disable_disk_based_gc         =     FALSE
        -max_size                      = 4273995775
        -absolute_max_size             =    4294967295
        -check_consistency             =    FALSE
        -print_debug_msgs              =   FALSE
        -expand_stack                  =   0
Please see chapter 'Specman Memory Consumption Is Too High' in the Specman documentation
**** Fatal error - leaving vManager:
Out of memory
vManager failed: Unexpected error
  • StephenH
    StephenH over 12 years ago
    Hello Jenny.
    Enterprise Manager is very old now and loading a huge number of runs into it will be pushing its performance to the limit. You mentioned 2000 VSOFs, but is that one test per VSOF (should be OK) or many tests per VSOF? In fact the VSOF is only part of the picture, the size of the coverage model (*.ucm) files is also significant.
    You can run the tool in 64-bit mode using the -64 option to emanager; this might gain you some performance as well, because the garbage collection will be less frequent.
    What I would really recommend though is for you to consider switching to the new vManager Client-Server technology, as this is our new tool. It's going to replace emanager and has a much more capable GUI and can handle vastly more tests and coverage data. There is some change to the use model so I think you should talk to your local Cadence Applications Engineer for guidance. If you don't know who your AE is, send me  aprivate message indicating your contact details and which company you work for and I'll put you in touch with the local AE.
    Steve
  • JennyYang
    Hi Steve ,
    Question 1:
     For the vManager Client-Server technology, which one should be download from
     Would it need a new license ? If yes, I won't install it.
    Question 2:
     Currently, I dont want to change tools. Even I use the option -64, it is very slow. How could I make it fast ? It seems that my memory configuration is not very good. Could give me some help to improve it ?
     All my coverage file data is only 136M. Why should it consume such big mem and such a long time?
     I am confused.
  • StephenH
    Jenny, the new technology is already a part of the Incisive isntallation, but only from Incisive 13.2. Yes, it takes a different licence, but because we will be phasing out emanager, at some stage you'd need to consider updating anyway.
    As for the performance of emanager, you should open a support case at http://support.cadence.com/ so that one of our engineering team can take a look at the specifics of your case; it's not really possible to help you based on the very limited information that you've posted here, and we may need to see the coverage model to diagnose the issue.
    The size of the UCD (data) files is not important, what really matters is the size of the coverage model (UCM file). If you have a lot of code coverage enabled this could be part of the issue.
  • JennyYang
    Hi Stephen,
    I had updated to INCISIV13.2 (14.1 software download from your web has problem with installation.)
    But the 13.2 emanager  performance does NOT improve .
    It tooks more than 10 hours to collect the 2000 vsof+ucd files (There are UCM files, each UCM file is about 550k byte)
    Do you have any suggestion for me to generate/collect the functioin coverage for several thousand test.
    Thank you.
