  2. Functional Verification
  3. Does irun 12.20 support multi-core simulation and how to...
  • Subscribers 67
  • Views 19097
Does irun 12.20 support multi-core simulation and how to do so
JennyYang
JennyYang over 12 years ago
Does irun 12.20 support multi-core simulation and how to do so .
I had ever use following "-processor" options. It seems that it does not work well.
irun -processor 4
irun -processor 4 -profthread
The version is :
irun: 12.20-s009: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
  • StephenH
    StephenH over 12 years ago
    -processor is used to bind the process to a given set of CPUs, so by saying -processor 4 you've simply asked the OS to always run irun on processor number 4. Not really what you wanted!
    There are various multi-core capabilities in Incisive, although in 12.20 it's a subset of what we offer in the current version 14.10; your local AE can help you choose the right settings for your design.
    Please note that 12.20 went of of support recently so you should consider moving up to a newer version such as 13.20 or 14.10.
  • JennyYang
    Hi StephenH ,
    Could you just tell me the option or which help doc (pdf) to find the help info.
    Thank you.
  • StephenH
    Jenny, the help tool is started from the Linux prompt using the command "cdnshelp". Once you've run it, type "multi-core" into the search box; the very first result it gives is describing multi-core simulation.
  • JennyYang
    In cdnshelp to search multi-core. I found the options : "-mccodegen -mcmaxcores 4"
    I do a same test with / without the options : "-mccodegen -mcmaxcores 4" , the simulation time are:
     without "-mccodegen -mcmaxcores 4" :      ncsim: CPU Usage - 9.2s system + 252.1s user = 261.2s total (329.4s, 79.3% cpu)
     with    "-mccodegen -mcmaxcores 4" :         ncsim: CPU Usage - 3.8s system + 203.3s user = 207.0s total (278.6s, 74.3% cpu)
        (And I found only 2 ncsim in the top command display)
    Question 1:  Is my options - "-mccodegen -mcmaxcores 4" used right ?
    Question 2: Why the performance improved is so little and only 2 cpu cores are used  ?
    Thanks .
