  2. Functional Verification
  3. coverage option weight
  • Subscribers 68
  • Views 24276
Umar Farooq
Umar Farooq over 12 years ago
Hi ,
Can anybody explain me how "option.weight" used..
if option.weight = 50 what happens and how it is going to effect the total coverage.
if option.weight = 0 what happen and how it is going to effect the total coverage.
  • Aurelian Amiq
    Aurelian Amiq over 12 years ago
    Hi, Umar!
    option.weight let's you define the influence of a covergroup/coverpoint/cross to the total coverage number of the above syntactic level.
    E.g:
     covergroup cg;
      aa: coverpoint a {
    option.weight = 3;
    bb: coverpoint b; //default weight is 1
    endgroup
    So if coverpoint aa is at 100% and coverpoint bb is at 0%, the total coverage of the covergroup cg will be 75%.
    If the weight of coverpoint aa would be the default value 1, the total coverage of the covergroup cg would be 50%.
    Imagine the weight as defining multiple coverage points for a. Like bellow:
       covergroup cg;
      aa_1: coverpoint a;
      aa_2: coverpoint a;
      aa_3: coverpoint a;
    endgroup
    And if you mention option.weight = 0, that coverpoint does not contribute to the total coverage of the covegroup. It's like that coverpoint does not exist inside the covergroup (even though you can still see the coverage value of that item).
    Best regards,
    Aurelian
