  2. Functional Verification
  3. case () inside gives errors with ncvlog
  • Subscribers 68
  • Views 22100
mkamal
mkamal over 12 years ago
The following code gives an error with ncverilog. Can any one figure out why ? (version 12.2)
case (ratio) inside
	     [990 : 1010] :  mon_txn.bit_rate_captured  = 3'b000;
	     [390 :410]   :  mon_txn.bit_rate_captured  = 3'b001;
	     [190 :210]   :  mon_txn.bit_rate_captured  = 3'b010;
	     [90 : 110]   :  mon_txn.bit_rate_captured  = 3'b011;
	     [35 : 45]    :  mon_txn.bit_rate_captured  = 3'b100;
	     [16 : 24]    :  mon_txn.bit_rate_captured  = 3'b101;
	     [8 : 12]     :  mon_txn.bit_rate_captured  = 3'b110;
endcase
(1)case (ratio) inside
ncvlog: *E,ILLPRI: illegal expression primary [4.2(IEEE)]
(2) [990 : 1010] : mon_txn.bit_rate_captured = 3'b000;
ncvlog: *E,NOTSTT : expecting a statement [9(IEEE)]
(3) [390 :410] : mon_txn.bit_rate_captured = 3'b001;
ncvlog: *E,ILLPRI : illegal expression primary [4.2(IEEE)].
(4) [390 :410] : mon_txn.bit_rate_captured = 3'b001;
ncvlog: *E,NOTSTT : expecting a statement [9(IEEE)].
and so on
  • Tudor Timi
    Tudor Timi over 12 years ago
    Seems that 'case (...) inside' is a SystemVerilog 2012 construct (I don't have an SV 2009 standard to compare). It's working starting with version 13.10. If you can't migrate, you'll have to rewrite your code.
  • Shalom B
    Shalom B over 12 years ago
    It is in SV-2009 also.
