  2. Functional Verification
  3. How to implement soft reset or functional level reset in...
  • Subscribers 68
  • Views 16939
How to implement soft reset or functional level reset in vr_ad register model?
subhash611
subhash611 over 12 years ago
Hi all,
In my project in the register model i have some fields which are sticky i.e. they are not effected by reset.For such fields how to implement in vr_ad? If it is possible, is there any chance to implement dircetly from the IPxact script(With the help of verdor defined extensions)?
 Please help me in this regard.
Thanks in advance,
Subhash.
  • Efrat
    Efrat over 12 years ago
    hi,
    VR_AD implements "stickiness variant" of the most common access policies. For example - RWS - Read Write Sticky - field is read/write access + sticky in reset.
    The list of sticky policies -
    extend vr_ad_field_attribute_t : [
       RWS,   // Read Write sticky
       RS,    // Read Only Sticky
       WS,    // Write Only Sticky
       RW1CS, // Read, Write 1 Clear Sticky
       RCS,   // Read Clear Sticky
       RW1SS]; // Read Write 1 Set Sticky, does not clear bits on 0
    Please note:
    VR_AD has notion of COLD and HOT reset. The bits are sticky only in HOT reset. The default reset is COLD. For perfoming HOT reset:
    instead of calling reset(), call:
            f1.reset_severity(HOT);
  • subhash611
     Thank you Efrat for your support.
