  2. Functional Verification
  3. ncsim: *E,IMPDLL: Unable to load the implicit shared ob...
  • Subscribers 67
  • Views 3797
ncsim: *E,IMPDLL: Unable to load the implicit shared object
sidharth1990
sidharth1990 over 12 years ago
While running simulation , i am getting the below mentioned error .
Can anyone help me to fix this error.
ncsim: *E,IMPDLL: Unable to load the implicit shared object.
OSDLERROR: /prj/.../v/_sv_export.so: failed to map segment from shared object: Operation not permitted.
ncsim: *W,LIBRUN: Could not load the dynamic library: ./INCA_libs/irun.lnx86.13.10.nc/librun
System ERROR: ./INCA_libs/irun.lnx86.13.10.nc/librun.so: failed to map segment from shared object: Operation not permitted.
ncsim: *F,NOFDPI: Function main not found in any of the shared object specified with -SV_LIB switchncsim: *E,IMPDLL: Unable to load the implicit shared object.
Is this related to DPI.
In my environment some c-code is included throgh dpi.
Sidharth
  • abhishektheone
    abhishektheone over 12 years ago
    Yes, I believe you need to add -loadpli1 option in your compilation option. -Abhishek
  • sidharth1990
    Hi Abhisek,
    I am using irun insted of going step by step compilation and simulation.
    I think -loadpli1 is used for ncsc and gcc option.
    For irun is there any command line argument ?
