  2. Functional Verification
  3. changing the name of waves.trn file
  • Subscribers 67
  • Views 17271
mkamal
mkamal over 12 years ago
Does any one know how to change the name of waves.trn located in waves.shm directory during simulation ?
Is there a command-line option that can be passed to irun to do this ?
This is because every time I run a simulation using irun, the old waves.shm/waves.trn file is overwritten by the new one.
 Thank you
  • andymont
    andymont over 12 years ago
    Hi, Why not just use a tcl file to create your probes and database? As it's tcl you can also use environment variables in there if you like. e.g. set db_name "$env(BRUN_TEST_NAME)" database -open $db_name -shm probe -create tb_top -depth all -all -memories -functions -tasks -shm -database $db_name regards, Andy
