  2. Functional Verification
  3. Gate level simulation with netlist and other RTL files
  • Subscribers 67
  • Views 15764
sidharth1990
sidharth1990 over 12 years ago
In my top level environment there are several modules are instantiated and one of the module is replaced by netlist.
i am facing  *F,INTERR: INTERNAL EXCEPTION.
Netlist should be top file or it can be instantiated inside other module.
Pls help me.
Sidharth
  • StephenH
    StephenH over 11 years ago
    If you get an INTERR message you need to do what it tells you in the log, namely file a support ticket at http://support.cadence.com/ and send them the *.err file that the log told you to send to Cadence. You will need to inform the support AE which Incisive version you are using, and give them enough detail to understand the problem. The message you posted above is so abbreviated that I can't even tell which stage of the flow it's failing in.
