  2. Functional Verification
  3. Accessing vplan attributes from console
  • Subscribers 67
  • Views 15729
andymont
andymont over 12 years ago
Hi All,
Does anyone know anything about the API to access vplan attributes from the console or from an e program ?
Specifically I want to be able to output this data in an arbitrary text format.
I know that I can already export a csv file using some batch API commands as shown below but I would like to directly access the parameters such as NAME and SIMULATION_ABSOLUTE_GRADE and then output them myself.
Has anyone done this or does anyone know how to do it ?
extend global {
  dump_vplan ( result_file_name:string=NULL) is {
    vm_manager.set_global_config("time_format","%F %T");
    if result_file_name == NULL { result_file_name = "results.csv"; };
    var all_sessions := vm_manager.get_all_sessions();
    var params: vm_export_vplan_parameters = new;
    params.set_vplan_tree_depth(1);
    params.set_information_kind(SECTIONS);
    var attrs: list of vm_vplan_attribute_t;
    attrs.add(NAME);
    attrs.add(SIMULATION_ABSOLUTE_GRADE);
    params.set_attributes(attrs);
    params.set_target_file(result_file_name);
    params.set_override_target_file(TRUE);
    vm_manager.export_vplan(params, all_sessions);
thanks in advance,
Andy
  • StephenH
    StephenH over 11 years ago
    You'd need to use the vPlan visitor API to do this kind of custom reporting. Or upgrade to the new vManager with its Tcl vPlan API.
