  2. Functional Verification
  3. "SVSEED set from command line" does not appear in log file...
  • Subscribers 68
  • Views 1926
bgpradeep
bgpradeep over 11 years ago
I used to have "SVSEED set from command line: <number>" appear in log file when i run a simulation with "-svseed <number>" command line option but am not seeing this line in log file after some updates to run script, so would like to know if there is any option that i need to run to see this line in the log file?
  • Selvavinayak
    Selvavinayak over 11 years ago
    Hi pradeep,
    Use irun -svseed seed_value[1,...]    -l log_filename.log
    It will helpful for you...
    selvavinayakam.na
