  2. Functional Verification
  3. Error in Elaboration in UVM environment
  • Subscribers 68
  • Views 27551
sunil kr
sunil kr over 11 years ago
I am trying to test the VHDL DUT in UVM environment and as i can see using the libverbose all the units are properly resolved when i used irun and it shows error in elaboration as below :
irun: *E,ELBERR: Error during elaboration (status 1), exiting.
I am not able to see any other error messages.
Can you please help me how i can further debug to know the exact reason for the error ?
  • Tudor Timi
    Tudor Timi over 11 years ago
    The full log file would be really helpful in diagnosing the problem.
  • sunil kr
    ncelab: *E,ICFNR: Cannot open instrumentation configuration file raccu_cov.ccf.
    Resolved design unit 'raccu_if' at 'raccu_tb_top.vif' to 'worklib.raccu_if:sv'.
    Resolved design unit 'raccu_if' at 'raccu_tb_top.vif_bfm' to 'worklib.raccu_if:sv'.
    Resolving design unit 'raccu' at 'raccu_tb_top.raccu_rtl_inst'.
    raccu raccu_rtl_inst();
    ncelab: *W,CUVFEP (./raccu_top_tb.sv,36|21): Too few entity port connections.
    ncelab: (RACCU.vhd,32): CLK
    ncelab: (RACCU.vhd,33): RST_N
    ncelab: (RACCU.vhd,34): RACCU_IN1_SD
    ncelab: (RACCU.vhd,35): RACCU_IN1
    ncelab: (RACCU.vhd,36): RACCU_IN2_SD
    ncelab: (RACCU.vhd,37): RACCU_IN2
    ncelab: (RACCU.vhd,38): RACCU_CFG_MODE
    ncelab: (RACCU.vhd,39): RACCU_RES_ADDRESS
    ncelab: (RACCU.vhd,40): RACCU_REGOUT
    ncelab: (RACCU.vhd,41): RACCU_LOOP_REG
    instance of module 'raccu' in 'worklib.raccu_tb_top:sv' is resolved to the VHDL architecture WORKLIB.RACCU:BEH
    Top level design units:
    raccu_parameters
    uvm_pkg
    raccu_test_pkg
    raccu_tb_top
  • sunil kr
    I have connected the ports using $nc_mirror and hence those warning message "Too few entity port connection"
  • Tudor Timi
    The error message is a few lines above that: ncelab: *E,ICFNR: Cannot open instrumentation configuration file raccu_cov.ccf.
  • sunil kr
    If i remove the coverage related files then i am able to resolve the issue. Thanks
  • Beth tamm
    Beth tamm over 10 years ago
    Hello, everyone I'm new here and want to know how to work with MATLAB software.
