  2. Functional Verification
  3. About timing precision of sdf file simulated in ncsim
  • Subscribers 67
  • Views 18959
daxingxing
daxingxing over 11 years ago
Hello Every,
Thank you for your kindness in advance.
Here is my problem
I find my  ncsim can only simualte the sdf file in precision of 10ps (round to 10ps)
For exampe,This is a simple BUF sdf information:
[syntax=verilog](CELL
  (CELLTYPE "BUFCLKHD30X")
  (INSTANCE U10)
  (DELAY
    (ABSOLUTE
    (IOPATH A Z (0.263:0.266:0.266) (0.257:0.259:0.259))
)[/syntax]
When I observe the timing sequence in simvision window, I found the simulator will round the IOPATH delay to 270ps when Z transfering from 0 to 1 because of the changing of A.
In my sdf file the Timescale (unit) is 1 ns. And in my testbench is 1ns/1ps. And according the tools documentation from cadence, the default timing precision of sdf elaberating/compiling is 1fs. I think that means we do not need to set any precision relating compiler option (like sdf_precision 1ps) in ma case. (BTW, I have tried such complier option, but help nothing).
How can I watch/oberseve a delay of 266ps from my simvision waveform window? Mnay thanks.!
My ncsim version is IES 2012, I thnik it was "latest" enough.
Many thanks.
  • Mickey
    Mickey over 11 years ago
    Could it be that the verilog for the buffer cell does not have a timescale directive and therefore the timescale being used for this cell is being inherited from the file compiled prior to it?
    try adding  "-timescale 1ns/1ps" to your elaboration.   The elaborator will then use this timescale for any files that do not have a specified timescale.
  • daxingxing
    Hi Mickey,
    Thank you very much! You are much much much clever!
    Yes the problem is in the standard cell verilog file the time resolution is 1ns/10ps!!!
    Thank you very very much!
