  2. Functional Verification
  3. Help with Optimizer (model parameters)
  • Subscribers 66
  • Views 13310
CarloDeSanti
CarloDeSanti over 10 years ago
Greetings.
Is there some way to use Optimizer (Orcad PSpice 16.5) in order to optimize model parameters (in the actual case, N and IS of a diode) and achieve fitting of the experimental data?
I read on the internet that it should be possible, but I was not able to make Optimizer recognize the two model parameters as optimizing parameters.
