  2. Functional Verification
  3. Getting SWIFT internal error:bad call of realloc:Failed...
  • Subscribers 67
  • Views 717
Getting SWIFT internal error:bad call of realloc:Failed to allocate block
usha sudhagar
usha sudhagar over 11 years ago
I am using following commands to save a checkpoint and later on wanted to restore it in order to create a snapshot,Commands used are
ncsim>stop -object test.active
ncsim>run
ncsim>run -clean
ncsim>save -overwrite worklib.first_snap
ncsim>run 2000ns
ncsim>restore first_snap
After the "save -overwrite worklib.first_snap" command got the below mentioned error.
Message!     [SDI/Verilog]
    SDI/Verilog does not support save - no SDI information will be saved.
Current simulation time = 0
    "/icfe_tools/incisv12.10.s012.hotfix/tools/uvm/uvm_lib/additions/sv/cdns_recording.svh", 75: $sdi_create_fiber(name,t,scope);
SWIFT internal error: bad call to realloc: Failed to allocate block: Size 188978564442, SaveRestore.c, Line 1340
File 'SaveRestore.c', Line 1340
Can anyone please help in getting this issue resolved or is there any other alternative way for saving and restoring checkpoint.
Usha
