  2. Functional Verification
  3. extend e language
  • Subscribers 68
  • Views 15378
extend e language
CatalinButnaru
CatalinButnaru over 11 years ago
Does anyone have another idea on how to extend a unit or struct by two value of a field at a time? (macro'less I would prefer, micro'with I already have a solution)
type foo_t : [one, two, three];
unit foo_u {
foo_field : foo_t;
extend [one, two]'foo_field foo_u {
// enjoy here
Catalin
  • Tudor Timi
    Tudor Timi over 11 years ago
    The best way to do it, from an encapsulation point of view, is to declare a separate determinant field that has the same value for 'ONE' and 'TWO'. Let's use a simple boolean in this case:
    extend foo_u {
      is_1_or_2 : bool;
      keep is_1_or_2 == foo_field in [ ONE, TWO ];
    extend TRUE'is_1_or_2 foo_u {
      some_field : some_type_t;
      // enjoy here
    This way, the extra code is truly common. Let's say that you define 'some_field' in both ways (with the macro and with the common determinant). This means, if you want to access 'some_field' in the macro case you have to cast to different types depending on the value of 'foo_field':
    'foo.as_a(ONE foo_u).some_field' or 'foo.as_a(TWO foo_u).some_field'
    In the other case, it's enough to say:
    'foo.as_a(TRUE foo_u).some_field'
    This cast will work for both 'ONE' and 'TWO' foos.
    The second approach is much better if you need to write generic code that handles fields defined in the extensions you want to add. If you don't need this and you only want to define extensions to methods, then the macro approach also works.
  • CatalinButnaru
    Good idea.
    Catalin
